Change the PIM interface status to passive to deny PIM control traffic on the interface.
  • The PIM interface is disabled.
The command you use depends on the required administrative state of the interface (enable or disable).
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface vlan <1–4059>
  2. Create a passive interface and enable it simultaneously:
    ip pim passive
  3. Create a passive interface in the disabled state:
    ip pim interface-type passive
    You must manually enable the interface.
  4. Enable a disabled interface:
    ip pim enable
Variable definitions
Use the data in the following table to use the ip pim command.
Variable
Value
active
Configures the selected interface. You can change the state of a PIM interface after you create the interface but only if you first disable PIM on the interface. An active interface permits PIM control transmitted and received traffic. A passive interface prevents PIM control traffic from transmitting or receiving, thereby reducing the load on a system. This feature is useful if a high number of PIM interfaces exist and connect to end users, not to other switches. The default is active. To configure this option to the default value, use the default operator with the command.
passive
